stock rearend replacement
Can I take a 8.5 out of a second gen camaro and replaces the axles and axle housing with the 7.5?
Are there 9in that fit (just thinking as I write this )
Who cares if it is a ford 9" setup, a 12 bolt or Dana 60. It will last and the fact that it's a direct bolt in, you should take to the fact that a 9" from moser, strange or whoever, there are probably zero ford parts in it.
The cost to make a 7.5 live is not worth it and usually on borrowed time.
I nearly forgot to quote since they are the masters of changing and deleting.
To the original poster You just might be the lucky reciptient of the cheapest S60 ever sold because I will gladly help with this one.
