top speed of 3.42
Old Jun 6, 2004 | 04:41 PM
indy500's Avatar
Default top speed of 3.42
what is the top speed of going from 3.15 to 3.42 with 3200 stall ?
is it high lost of top speed ? and is it good combo to high speed highway drive ?
Old Jun 6, 2004 | 11:48 PM
Colonel's Avatar
3.15? I assume you're speaking of a C5 'Vette in which case the stock tire height is 26.66" in the rear. Assuming a 6200 rev limit and adequate power (see, you're going to be power limited NOT gear limited in either case) you could see roughly 150 MPH in D or 215 MPH in OD. With 3.42s you're looking at about 140 in D and 200 in OD. As I said, regardless of gear you're going to see your top speed in OD WELL before redline unless you have some MAJOR power.
