9inch rear question
Old Aug 1, 2015 | 08:56 PM
GMtechmatt's Avatar
Default 9inch rear question
i have a 9inch rear narrowed 3inch'sperside what backspacing on rim is needed? this is in a 2002 z28 stock fbody brake system
Old Aug 1, 2015 | 10:00 PM
HISS's Avatar
Stock width with a 10" wheel is 7.5". So if you run a 10". 4.5" would be the correct offset. Unless of course it's mini tubbed, then obviously you could run a much wider wheel, and play with the offsets.
Old Aug 3, 2015 | 01:11 PM
MidwestChassis2's Avatar
I'd suggest installing the rear end in the vehicle and measuring for proper backspacing. Purchasing wheels isn't cheap and it can be a hassle to return them if ordered wrong. Figuring proper back spacing is as easy as using two straight edges.
