locked rearend help!!
my question is if I but a new pinion and gear set will that fix my problem?
and would 3.73 gears be the way to go instead of the stock 2.73?
Don't forget that you'd want to tune your car for the gear change also, so shift points, speedometer, etc are all correct.
Not sure how much it all will cost to do this. It may be easier/cheaper to drop an entire used rear into it, or just bite the bullet and upgrade the rear to something stronger.
98s' had Auburn posi,99-02 had Torsen posi. Replacement rearend has to be compatible with cars' channel system. 3 channel-ABS only,4 channel-ABS and TC.
