9" question
Old Feb 29, 2016 | 04:29 PM
farmington's Avatar
Default 9" question
Friend has a 9" rear for sale. Had 4.10 gear and a spool. I can live with that but my car is 4 channel. Can the abs and tc be tuned out or is it possible to get rear set up for 4 channel.
Old Feb 29, 2016 | 07:26 PM
SteenH's Avatar
Should be possible to make it work
But you can also take the easy route and tune it out
Old Feb 29, 2016 | 07:35 PM
farmington's Avatar
I have no problem tuning them both out just wasn't sure if it was possible. Will it keep the lights on the dash off too?
Old Feb 29, 2016 | 10:32 PM
blk00ss's Avatar
No. But you call pull the cluster and pop those lights out lol.
Old Mar 1, 2016 | 04:16 AM
SteenH's Avatar
I was under the impression that the light could be tuned out. I apologize for the false information if not.
Old Mar 1, 2016 | 09:35 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
ABS/TCS is not in the PCM on 4th gen cars. Most people just cover the bulbs behind the cluster face, de-solder the bulb connection, or pull wires from the harness connector under the dash.
