is this the correct install kit for moser 9"? installing some new richmond gears in my moser build 9" rear. The first kit i ordered from summit had the smaller carrier bearings in it which were too small for my 3rd member. here is the kit im looking at, but i cant find any specs on the bearings it comes with to confirm it will work. http://www.summitracing.com/parts/rmg-8310051/overview/ here is the numbers and measurements from my old races/bearings carrier bearings LM104911 3.250" OD pinion inner bearing HM89410 3" OD 7/8" depth pinion outer bearing M88010 2 3/4" OD 11/16" depth pinion has 28 splines using 35 spline axles any help or info would be much appreciated |
Give us a call, we can set you up with the right parts the first time. We can beat mail order prices as well! |
© 2024 MH Sub I, LLC dba Internet Brands
