Eliminating traction control for 9"
Old Jun 15, 2016 | 02:25 PM
Sean Tee's Avatar
Default Eliminating traction control for 9"
I "think" i searched my answer but not 100% sure.
Currently have 4 channel 10 bolt and wanting to go for a 9" now.
I hate the traction control on the car, never use it, always turn it off.
So now if I order my 9" do I HAVE to get 4 channel or can I just get 3 channel and not have the traction control?
Also, don't really care if I have a dash light, just want to make sure it doesn't cause something else with the EBCM. Thank you
Old Jun 15, 2016 | 02:49 PM
MidwestChassis2's Avatar
You either set it up for 4ch and have traction control and ABS or you eliminate it. Making 3ch work on your end would take a little bit of work on the vehicle side.
Old Jun 15, 2016 | 03:10 PM
Sean Tee's Avatar
So I can eliminate ABS AND TCS? Dont mind losing both honestly.
Old Jun 15, 2016 | 04:11 PM
josh4ku's Avatar
Unplug your abs sensors on the rear and bam both eliminated.
Old Jun 16, 2016 | 06:54 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
As has been posted, if you don't hook up the ABS and TCS they won't work. Your brakes will work just fine, you'll have old school brakes where you can lock them up if you slam on them. You'll have the lights on the dash to contend with, and you can't turn them off through tuning. The easiest thing to do is to remove the gauge cluster bezel and paint the bulbs black. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jun 16, 2016 | 08:26 AM
josh4ku's Avatar
Forgot to mention you will lose your cruise control if you unplug those sensors.
