new gears screaming
Old Sep 1, 2016 | 01:49 PM
tannerwinberg's Avatar
Default new gears screaming
Just swapped out my stocks gears for some motive 3.73s. The break in procedure probably wasn't exactly perfect. I ran about 10 miles and let them cool. then went back out and ran about 10 miles and then did a hard pull 60 up to around 120 and now there howling LOUD. Does this usually happen and go away or are they toast?
Old Sep 1, 2016 | 02:20 PM
MidwestChassis2's Avatar
Once a gear is not properly broke in and makes noise it will always make noise.
This is our break in procedure.
Old Sep 1, 2016 | 10:03 PM
01ssreda4's Avatar
Yep........
Old Sep 2, 2016 | 08:33 AM
took it out last night and after 20 miles of easy driving, the noise went away. might just take it through a couple more heat cycles and see how it acts.
Old Sep 3, 2016 | 09:55 PM
McGinnis's Avatar
If they make noise now they will continue too, unless you just drove it around the block you can usually readjust your pattern. As a side note Motive gears will usually whine a little over a small speed range(60mph) typically and there is nothing you can do short of buying a different set of gears . If they make a lot of noise on the drive side the pattern is most likely way off. If you have a loud exhaust or radio you will never notice, but if you want to achieve a perfect "silent" set you will need new gears. The quietest set out there is the OEM AAM gears they are machined differently and run a much tighter backlash, they are easier to set up and the closest thing to a "silent" 10 bolt you can get. Our rear ends are hard to get quiet and are finicky because they are in a uni-body car with a torque arm, and an axle less then 2ft from or seats.
