Sealed Bearings
Old Apr 26, 2017 | 06:19 AM
Stans 57's Avatar
Default Sealed Bearings
Recently had new axles made for my dropout style rear differential car. The old bearings had one sealed side, the other side was open to receive gear lube. The new bearings are double sealed type. Are they any good for a street car? The shop/sales told me they use them on race cars and that the racers change them quite often, which makes me think they aren't good for street use.
Old Apr 26, 2017 | 08:36 AM
conexion914's Avatar
Is this for a 9"? My rear end uses 9" housing ends and I used Timken Set 20 bearings which use an outer seal and as long as there is no inner axle seal the bearing is lubricated with gear lube.
I bought Green bearings originally which didn't fit, but are considered race bearings. Does the bearing you have have an o-ring around the bearing case? From what I've read the Timken style can better handle side loading and would therefore be better in a street application.
Hope that helps some.
Old Apr 26, 2017 | 09:20 AM
Stans 57's Avatar
It is for a drop out early Chevy type center section. I'm sure the double seal bearings are made for Fords too so it may be a moot point anyway. You might call Currie if if desired.
I have heard of the Green Bearing but that's all. I have a set for my Chrysler/Chvey differential that's just collecting dust under the bench. They are suppose to be better than the stock type. I don't know what the Timken style is but I have heard Timken got bought out or is no longer in business.
I was told by the folks at some high end mgfring place, RKF? that all bearings are made in China, except theirs. Upon closer inquire it was found that my style bearing from them was outsourced and did not have their normal 3 year warrentee, only 1 year.
As for the double sealed bearing, it was explained to me the bearing has a seal on each side (may be removable) and is sent packed with Lithium grease. (I would prefer Moly) It has two rubber o-rings around the outside case.
Actually it doesn't exactly help me, however my reply may help you and others, which is a good thing, if it turns out these are good street bearings.
Hopefully someone here will have experience with this bearing on the street and reply. Regards.
Old Apr 27, 2017 | 12:45 PM
MidwestChassis2's Avatar
For a street car you want a tapered bearing which is the Timken Set 20 he mentioned.
Which will be like this.
