ANOTHER QP 9" rear question
Would the QP rear torque arm bracket have to be purchased as well, and would it work for this torque arm?
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Theirs like any cast nine inch has a problem with moving the torque arm a minimum of a half inch toward the drivers side to make room to clear the yoke. Doing this means the torque arm beats off the floor board and no amount of modification can stop this because of their bracket onto a bracket system.
We just had a car in the shop in attempt to fix this problem for them and the only solution was to purchase our two piece race arm and have us modify the mounts to work or cut the floor out to give room. They chose to cut the floor out. The minimal amount that you can take off of a torque arm bracket is not enough room. They didn't have our stock style torque arm to begin with but like stating above it doesn't matter the torque arm.
We probably sell 6-7 a year two piece race arms for this exact reason. It is almost easier to choose a different rear end.
