Ring and Pinion Q!
Old Jun 28, 2004 | 06:06 PM
00Streak's Avatar
Default Ring and Pinion Q!
After installing the rear end. breaking it in, and driving the spool for about 5000 miles. I started to wonder if something I noticed was normal.. or not normal. When I jack the rear end up, i get play in the wheel. IE: i grab the DS wheel and wiggle it forwards and backwards. It moves about an inch before enguaging the other tire. Is this normal or bad? does it mean that moser built my 3rd member wrong? Im considering taking the whole thing back out again and rebuilding the 3rd member due to whine and what sounds like grind. My money is on moser not building the 3rd member right but i need your opinions.
TIA Scott
Old Jun 28, 2004 | 11:43 PM
taqwache's Avatar
yes it is normal to have that much slack but considering that you have a spool, then yours might be too much. its hard to tell over the internet. i would just take it apart and check it out.
Old Jun 28, 2004 | 11:46 PM
taqwache's Avatar
oh yea. make sure that you are not checking it with the tires off the car because you will feel the slack between the axles and rotors.
Old Jun 29, 2004 | 08:34 AM
00Streak's Avatar
Naw, I was checking with the tires on it.. easier to check.. are there any books out there on how to "properly" build a 3rd member?? like backlash, bearings, etc??
TIA
S
Old Jun 29, 2004 | 09:28 AM
taqwache's Avatar
i am sure there is put cant think of any at this minute. the auto manuals usually leave that info out.
