95 Rear end
Old Nov 21, 2017 | 10:07 AM
Alex Richardson's Avatar
Default 95 Rear end
So the rear end in my built 95 lt1 feels like its missing some teeth, i wanted to sell the car soon tho, so i dont want to put more than a couple-hundred dollars into fixing her. I have worked on cars a long time and so has my dad but we cant setup a rear end from start, were trying to do a str8 swap, my question is what cheap/used rear ends would fit my car? Would a 93/94 or 96/97 rear end work? I dont belive my cars has TC, can i put a rear end that has TC on it?
Old Nov 21, 2017 | 12:26 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
1995 thru 1997,others might post up for that question.
TC (TC & ABS) 4 channel started as an option in 1995. TC & ABS has a sensor in each of the rearends' backing plate/dust shield. ABS only (3 channel) has only one sensor located on top of the center of the rearend. If you put a TC rearend into a non-TC car,the dash's ABS and TC lights will be permanently on.
It's best if you first determine which system the car has !
Old Nov 22, 2017 | 11:56 AM
biketopia's Avatar
Installing a set of gears into rear isn't that hard, especially if you are leaving the carrier alone. Plenty of how too's out there. Hell scoring a set of used gears off here or CL would be cheap and easy.
