!!Need help!! with my 9" install
Old Mar 18, 2018 | 11:42 PM
Bspeck82's Avatar
Originally Posted by Crf450r420
Based on the pictures it looks like the LCA mounts are way off. Remove the springs and jack the axle to the bump stops and see if they hit in the middle of the tube.
So so I remove the springs and Jack the rear end up to the bump stops. The pictures below will display my results very interesting. Passenger side
Driver side
Old Mar 19, 2018 | 04:27 AM
Launch's Avatar
That looks wrong. But the only way you are truly going to know if the LCA mounts are welded correct, is to put the axles in, bolt the wheels on, fit the torque arm, and sit the car on the ground under it's own weight.. and look at where the wheels sit. You can move the rear axle back/forth with adjustable LCA's.
When I fitted my S60 I had to move my rear axle 1/4" back over where it was standard with the adjustable LCA's so I could reuse my PST Cm driveshaft I already had (which thankfully was about 3/4" too short for the previous setup and I squeezed even more out of it by machining down my slip yoke a little).
You can move things around and get it right without redoing the housing.. Founders adjustable LCA's are cheap option. I have their heim joints on both ends. It's loud and clunks sometimes but IDC, I've setup this car so far for all out performance.. and perform it does for the current cam-only turd that it is.. it's a gutted hardtop 94 with nothing in it but 2 front seats, no swaybar, no abs, no A/C, the under dash is gutted, rewired, no factory bumper supports, half the car is sitting in my garage LOL. It easily walks other much higher modified heavy LS cars even LS3's. Every single time I drive it I think how the "F*CK" is this a cam only LS1?! I've owned several LS powered cars, but this was my first LIGHT 4th gen. I can only imagine it with some real HP.. i'll be afraid to WOT it.
Old Mar 19, 2018 | 09:28 AM
Bspeck82's Avatar
I can't move the rear end forwards or back anymore, the panhard, shocks, LCA and ta wouldn't allow it. The LCA brackets are welded into the wrong location. I'm going to call them today and I hope they are willing to work with me. The fact that I have to tear it back apart makes me not very happy. I'm not cutting and machining my yoke because they screwed it up.
Old Mar 19, 2018 | 07:02 PM
Launch's Avatar
I was just pointing out that if you need to move the rear axle only 1/4" or so, you can do so with adjustable LCA's and everything just moves with it.. as I found out with mine.
If your LCA brackets are welded on more wrong than that amount, yeah, no good.
Old Mar 20, 2018 | 12:02 AM
Crf450r420's Avatar
Thought there was a good chance they were off. At least you can stop guessing.
Old Mar 20, 2018 | 10:01 AM
Bspeck82's Avatar
I have contacted them twice now and sent them pictures to Mikes phone as he requested. He has recieved the pics and told me he and his guys were going to look at them in the afternoon and get back with me. I sent the pics at 8AM yesterday...I made the follow up call at 11am yesterday. Haven't heard back yet.
Old Mar 20, 2018 | 10:46 AM
Crf450r420's Avatar
Might be less trouble and it would be faster to get a local guy to just move them where needed. Keep in mind the pinion angle still has some effect and you need it correct to figure out how far they need to be moved.
Bad customer service sucks, but some places are small and it's harder for them. I work at a small shop, so I know how hard it can be.
Old Mar 20, 2018 | 11:48 AM
Bspeck82's Avatar
I understand that but they need to put it back on a jig and get it right this time. For 2600 bucks I expect it to be right the first time. Either the welder was having a bad day or the jig was not set right. Either way, I shouldn't have to pay more money to have someone else correct their mistake.
Old Mar 20, 2018 | 10:05 PM
Bspeck82's Avatar
MAJOR UPDATE
After about an hour on the phone with Mike we went through some troubleshooting to get this problem sorted out. I removed my BMR adj torque arm and reinstalled my UMI non adjustable torque arm I had before the 9". Well guess what, the perches aligned up and the springs fit...I then layed the arms on top of one another and the BMR arm was not even close to being correct. I adjusted the bottom adjusting tab until they matched back up with one another (the arms) and tried again. New problem. After bolting the TA to the housing and the crossmember with the bushing installed on the nose of the arm I tried to install the crossmember with the TA bracket installed on the housing. Well this is impossible because the crossmember is pushed about 1 inch too far foward and I can't bolt it up to the car. I have no movement with the arm. I am going to have to figure this problem out when I get some daylight. I'll keep you guys updated.
Old Mar 21, 2018 | 12:08 AM
Crf450r420's Avatar
Both of those joints are adjustable. You don't have the other one extended also?
Old Mar 21, 2018 | 09:52 AM
Bspeck82's Avatar
I adjusted the bottom adjusting joint but haven't touched the top yet. The top TA joint has about 2-3 threads showing. I was going to mess with it today.
Old Mar 22, 2018 | 10:08 AM
  #32
Bspeck82's Avatar
Issues solved. Mike at QP and Eric at BMR were great to deal with. Now I would like to ask, what should I do about my brake lines and E brake? I don't want to weld anything, is there a kit to make them neat and not rub on anything? How do I go about getting the ebrake bracket and lines installed. Thanks.
Old Mar 22, 2018 | 05:47 PM
  #33
Crf450r420's Avatar
So what was the issue? BMR bar on the bracket upside down and making so far off it couldn't adjust to work?
Old Mar 22, 2018 | 07:17 PM
  #34
Bspeck82's Avatar
The torque arm adjuster nuts were nowhere near where it needed to be to work with the 9-inch. I tightened up the Top Nut as much as I could and when I bolted in the crossmember I was able to Tug it back just enough so that I could thread the crossmember bolt in the hole and put it all together. I got everything bolted together and tightened but the shocks are bending back towards the front of the car slightly. I haven't had time to set pinion angle properly so I will do that and I'm sure that will alleviate the problem. My next step is to figure out what I am going to do to tidy up the brake cables so that they don't get damaged and what I should do with the E brake bracket. I see Moser sells a nylon clamp that goes around the axle for the brake lines for $10 and I've heard of people cutting the E brake bracket so I will do some investigating and calling around to see what the best option would because I don't want to do it the sloppy way I would like it to look nice. But I am really not interested in welding anyting.
Old Mar 22, 2018 | 07:27 PM
  #35
Bspeck82's Avatar
When I received the BMR arm I just assumed it to be configure just like the non adjustable Umi arm. But when I put them one on top of the other it was clear that the BMR bar was nowhere near the stock angle of a non adjustable arm. It was something so simple I should have checked it before I put it in the car. I was sure that I would not get enough adjustment out of tightening the top mount of the torque arm but it appears that it was just enough. I did not touch the quick performance 9-inch housing bracket at all. It also looks like I might have to cut a coil or two because just by looking at it I can tell that this is going to make the rear of the car sit a little higher.
Old Mar 22, 2018 | 08:02 PM
  #36
dojob's Avatar
Heater-hose the rear springs. Take out the upper insulators. Buys you a decent amount of drop
