Tach and Speedo not reading correct?????
When I am doing about 40-45 mph the car says I am going 80-85 mph and the tach is around 3k Rpms but you can tell the car is only running around 1500 rpms
Any ideas?
Matt
Any ideas?
Matt
You issue is likely the needles need to be re-stuck to the correct positions. The scanner is also part of getting that right too, so you can verify rpm. Check speed on a gps and restick it where it's most accurate, provided that your sensor is good.
