Ford 9 carrier questions?
i bought a 1999 Camaro with a Ford 9 in it. I removed the rear end noticed its a Moser housing with a strange iron center section (3.73) and bear axles (35 spline). My friend and I put a big bar on each side of the hubs between the studs and pulled separate ways. The axles didnt break free so I am assuming its a spool rear end.
I dont want a spool for the street so what exactly do I need to know when ordering a new center section?
The rear end has no ABS and my car is set up for a 3 channel. What all does that take to put in now?
Thanks for the help!!
Here is my link to the Moser center section. It would be much easier not to try to add ABS to your car. You could order the center section with the ABS ring but in order to be able to use it you would have to drill into the top of the housing and weld in the bung for the ABS sensor. Bob
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
https://shop.brutespeed.com/Moser-5W...ser-5W9F35.htm
Wavetrac 35 spline - Requires a 3.250 case
Lifetime warranty
https://shop.brutespeed.com/Moser-5T...ser-5TT690.htm
Detroit Truetrac Ford 9" Rear -- 35 Spline - Requires a 3.250 case
