rear end issue
I can shift out and in from Park to Drive. No issues. differential fluid was topped off a month ago and was checked yesterday (still fin). My main concern is when I shift to Reverse from Park and try to move I advance about 5 feet then my truck seizes. It will unlock only after I play with it back and forth then i can finally pull out. Same thing occurs when shifted in Neutral. Suddenly locks up and stops turning. Have had that problem for a month now. As well as my truck pulling to the right slightly as i drive down the road. Going to replace the springs and cylinder in the rear Drums the see if that helps with either issue but i'd appreciate some feedback.
