Gearing question
Old Feb 21, 2019 | 11:30 AM
Stockcarracer's Avatar
Default Gearing question
Hi everyone I'm new to this forum. I'm currently building a gen 4 camaro into a circle track stock car And i have to use the stock 10 bolt rear differential the highest gear set i can seem to find is a 4.56 is the rear end to small to a accommodate anything bigger? Ideally i would like to run around a 5.25. Can anyone shed some light on this?
Old Feb 21, 2019 | 11:32 AM
HioSSilver's Avatar
You can always use 3rd gear instead of 4th to reach the ratio you desire.
Old Feb 21, 2019 | 11:45 AM
AnotherWs6's Avatar
Yes, rear end is small. These gears get weaker as they get numerically taller. Maybe OK on dirt, I dunno. But I wouldnt think a manufacturer would want to be liable for something in the 5.xx range.
Old Feb 22, 2019 | 10:02 AM
01ssreda4's Avatar
4.56 is the highest ratio i can recall seeing.
