Help with moser axleshaft please!
Old Mar 31, 2019 | 12:12 PM
T/AWS6969's Avatar
Default Help with moser axleshaft please!
I have been fighting with this last few hours I can only get the driver side to go in so far. I have taken it out 3 * to double-check the spline etc make sure everything is fine. It looks like the shaft is only going in a little over an inch into the center section I don't know if that's up to par or not? Meanwhile the passenger side went in fine 0 problems at all ..I only had to tap a few times with a mallet to get it to go in all the way. I have hit the driver side end repeatedly and won't go in any more other than this.(pics) thanks for any input guys!
Old Mar 31, 2019 | 07:48 PM
Jtm2085's Avatar
Is it a 9inch? If so, passenger side axle is longer than the driver
Old Mar 31, 2019 | 08:07 PM
T/AWS6969's Avatar
It is a 9-inch and I do have the correct shafts going in each side. I even just got done Borescoping it to make sure there was no obstruction and it kind of looks like Moser gave me a shaft a bit too long. I guess I will welcome myself to the club after more research it looks like that this has happened to others before..
Old Apr 4, 2019 | 02:57 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Alan found out one of the housing ends was slightly bent, which was the cause of his problems. I'm glad you got it figured out Alan!! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
