Pinion angle help
Old Sep 16, 2019 | 10:41 AM
chines72's Avatar
Default Pinion angle help
Did a Ls swap in a c10. Using a hooker black heart cross member. My motor and trans has a 4.40* downwards angle. My diff is sitting at .0*. So I decided to use a 4* degree shim. My leaf springs sit on top of rear end. To raise, do I put the shim in from the front or the back?? Hopeing this will fix my problem!
Old Sep 20, 2019 | 08:03 PM
NewEnglandFormula's Avatar
to raise the pinion angle you need to put the shim in front. I would ask some other c10 owners with a similar setup and see what they are running for an angle.
