Low slack differential
Old Sep 10, 2020 | 02:24 PM
98cherrySS's Avatar
Default Low slack differential
I'm curious who manufacturers a really low slack differential. I'm not speaking about gear setup or backlash. Just the internal differential components. I run a PowerTtrax (Torsen Style) 9" and it is loose. I've actually had two and both behaved the same way. My understanding is that Torsens are naturally loose and after tearing one down, I can see why. I'm thinking auburn style differentials are tighter in concept but I'm curious what others have experienced. This is all in an effort to reduce the driveline slack. Please share you thoughts.
Old Sep 10, 2020 | 09:44 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
Auburn and Eaton posi both have spider gears, so only the spider gear set and the 'lash' of the pinion to the ring gear would be all. And then there's the fit of the axle splines into the carrier.
Old Sep 21, 2020 | 08:22 PM
skinumback's Avatar
I’ve had a Eaton posi in my 8.5 for 16 years with no issues. Works great on street, very quite operation. I make a few passes per year with slicks with no issues.
