Ford 9" swap Spool to Wavetrac
Old Oct 18, 2020 | 05:51 PM
JimTA's Avatar
Default Ford 9" swap Spool to Wavetrac
Tired of the spool on the street and would like to swap to a Wavetrac...
It is a quick performance 9 with their HD spool, I don't know anything about the dimensions, are they standard in any way?
My question is (I know not much info) should I expect axle length to remain the same if I swap to the Wavetrac?
Old Oct 19, 2020 | 08:12 AM
MidwestChassis2's Avatar
You will have to measure for axle length after you swap out the differential as no one can tell you that with out checking. However if the axles have proper engagement for a spool they will be to long for any other type of differential.
Old Oct 19, 2020 | 08:32 AM
JimTA's Avatar
I figured.. but worth asking before I order parts and tear it down
