gear changing and shift points
Old Jul 18, 2004 | 09:15 PM
sleeperstyle's Avatar
Default gear changing and shift points
i am gonna swap rear-gears, probably from my 2.73's to 3.23's or 3.42's - maybe even 3.73's(i am swapping because i could use a rear-end rebuild anyway and i don't like my long *** gearing- 1st till 50mph and 2nd till 90mph...)
i have a 98 a4 forumula. my question is- if i swap out to say 3.23's do i need a ls1 edit tune or hpp3 adjustment to make it shift correctly or the computer will compensate and shift at the normal 6k rpms point? how about with 3.42's or 3.73's? i would like to be able to put off the tune till i really need it down the road
also- if i do need a tune are there options like a trans computer from a 3.23 a4 car (i work at a junkyard and could get one cheap)..
thanks in advance.
Old Jul 19, 2004 | 07:13 AM
i guess it is THAT stupid of a question or nobody knows? ttt
Old Jul 19, 2004 | 09:57 PM
Colonel's Avatar
Your speedo will be off by the same amount as the gear change. In other words, your PCM won't know the difference. It'll shift.
(Not a dumb question.)
