8.8 ABS - Tone ring thickness?
Have my 8.8 all ready to go together, but working on a tone ring to use stock ABS sensor... I have a cad? file from Hiltsy, but it doesn't mention the thickness needed...
I see 2 thickness measurements mentioned for 2 or 3 series carrier for stock 10 bolts - but I have no idea for the 8.8 - anyone have ideas?
2 series: .230" (15/64)
3 series: .540" (17/32)
Have sent some PM's to people as well, will update this with info
Thanks!
Edit - so I think i'm just being dumb - this gets put on the carrier - so I measured my new one (FPRacing T-2R) and its .315"
The thickness of the 2 series should be adequate as long as it's centered to the sensor and a same distance away from the sensor.
The machine shop said they have .25" plate, so i'll have them just use that and no milling for thickness... this has it less than 1mm on each side, shouldn't matter here at all i'm guessing.
Could you comment on material? they stock aluminium and stainless steel
Thanks!
So I assume aluminum will not create a signal with the sensor. 300 series stainless steel has no magnetism, 400 series stainless steel has weak magnetism/strong magnetism depending upon the specific alloy.
1018 Cold Rolled Steel in particular - have passed this along to the MS.
Cheers
Once it's on at it's proper place, drill a hole (neither the ring or carrier is hardened) on the diameter where they meet and then put/press a pin in the hole. Tacking it in place seems too permanent.
