Dif rebuild
Old Jan 2, 2021 | 06:17 PM
01ws6bir's Avatar
Default Dif rebuild
I’m looking to upgrade my 10 bolt with 373 or 410’s any advice would be great
Old Jan 2, 2021 | 06:49 PM
Welcome to LS1Tech! We have a dedicated forum for just what your looking for. Post your question over in the Gears And Axle sub-forum. You’ll get plenty of help over there.
Old Jan 5, 2021 | 07:04 AM
JohnnyBs98WS6Rag's Avatar
My advise is, unless you are still running a V6, ditch the 10-bolt and upgrade to a 12-bolt, 9" or S60. IMO, the factory 7.5" 10-bolt isn't worth sinking a dime into, it is weak and will break sooner or later. Swapping to a steeper gearset only makes it more likely to break since it increases the side-loads on the pinion for a given driveshaft torque.
