Should it handle this
Old May 18, 2021 | 10:28 AM
03LQ9's Avatar
Default Should it handle this
Hi, I have a 2000 Z28, stock engine with headers, under drive pulley and tuned. The 10 bolt has been rebuilt with 3:73 gears, girdle, cap studs and axle tubes welded and solid pinion spacer. Full weight it runs 11.7x @ 113 with 1.57 69fts. The rear whines loud after one trip to the track. Is this too much for the stock rear or was it probably put together wrong? It was having a slight whine before the track day so I’m not sure if something was wrong before. Any thoughts?
Old May 18, 2021 | 01:29 PM
speedfreak440's Avatar
Stick or Auto? If stick it's on borrowed time, if Auto it SHOULD hold.
Old May 18, 2021 | 02:47 PM
03LQ9's Avatar
The car is an auto with a 4,000 stall. I think the rear end should hold up to a stock engine stalled auto so I’m debating on having someone else put another set of gears in it and trying again?
Old May 25, 2021 | 05:06 PM
Kawboom's Avatar
Re-torque the pinion bolt? Maybe a good launch seated the bearing race harder than the 10 ton press they used to assemble the thing.
