better rear diff of the 2
Old Oct 14, 2021 | 01:18 PM
69PrimedC10's Avatar
Default better rear diff of the 2
I'm helping my son build a 99 z28. i haven't pulled the cover yet but something is wrong in the diff. However I do have 2 other rear diffs ready to go. One is out of a 93 Trans Am WS6 6 speed car and the other out of a 99 Camaro SS SLP auto car. I know they are basically the same but was wondering if one might be better then the other or are they basically the same?
Old Oct 14, 2021 | 02:12 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
A couple of things here... first, there was no "WS6" Trans Am for 1993; this package was not introduced as a trim level on 4th gen F-body until 1996.
Second, the LSD for the earlier 4th gens was an Auburn unit, but in 1999 GM switched to a Torsen LSD. So the '99 SS would have a Torsen, UNLESS it was ordered with the optional Auburn upgrade from SLP (only optional on SS/Firehawk). All else being equal, I would always choose the Auburn over the Torsen, but as these are *used* units they are likely not equal in condition. So you'll probably get the most life out of the one that has the lowest miles and/or has seen the least abusive usage. I've had both versions (Auburn and Torsen) across several different 4th gen F-bodies, and the Auburn just operates better IMO (smoother engagement, no chatter).
Are you swapping gears as well? The '99 SS auto would have come with a mandatory 3.23 gear option. I seem to recall the '93 M6 cars also coming with a 3.23 (vs. the later 3.42 gears for manual cars), but I could be mistaken on that.
Old Oct 14, 2021 | 02:26 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
^^^ as above plus TC vs non-TC. does the current 99 Z28 have TC ? the 93 definitely would not have it, the 99SS could. No compatabilty in the systems and would cause warning dash lights on.
Old Oct 14, 2021 | 04:38 PM
Thanks guys!
Old Oct 15, 2021 | 08:07 AM
JohnnyBs98WS6Rag's Avatar
Well...........yes and no. RPO WS6 was used in '93 as a optional suspension package (I'm not sure what it included, but I'm assuming it was similar to the WS6 RPO in the late '70s 2nd gens ... also not sure if any 3rd gens used the WS6 RPO). According to CompNine, this was extremely rare, only 15 '93 Firebirds (5 Formulas and 10 T/As) were built w/ RPO WS6. Indeed, you are correct that these cars were not "outwardly badged" as being equipped w/ this WS6 suspension package, and it certainly didn't include the "Ram Air" features of the '96+ models.
You are also correct that no 3.42 rear gear was available in '93, the M6 cars got the 3.23 gear, A4 cars got either the 2.73 or 3.23.
Old Oct 15, 2021 | 12:23 PM
RPM WS6's Avatar
In fact, my '89 Formula 350 also included the "WS6" RPO. But, again, this was not an outwardly badged (other than the center caps) package as we see with the 1996-'02 examples, so folks don't typically refer to these as "WS6" cars either. I do seem to recall there being two levels of Trans Am in the early 4th gen years though...Trans Am and Trans Am GT (none were actually called a "WS6" nor badged as WS6 or GT). Other than the raised deck spoiler (which I think was RPO T43), I don't know what else the "GT" package consisted of.
Old Oct 16, 2021 | 02:37 PM
one more ? can I use the rear end out of a 99 plus fbody in my 93 TA? I picked up a moser 12 bolt. It has the wiring going to the diff, it came out of a 99.
