Driveshaft length
Old Feb 25, 2023 | 12:51 PM
Mike Cordero's Avatar
Default Drive shaft length
Ls1 automatic Camaro, drive shaft length?
Old Feb 25, 2023 | 01:05 PM
Default Driveshaft length
Length of the drivedñshat in a 98 ss ls1 camaro?
Old Feb 25, 2023 | 01:15 PM
Default Driveshat shape, manual vs auto
Do the manual car is diffetent from the automatic, the driveshat? Length or something. I have two of them and one has like a metal drum at the beginning of the side that goes to the tranny?
Old Feb 25, 2023 | 01:18 PM
Default Driveshaft
Do the manual car is diffetent from the automatic, the driveshat? Length or something. I have two of them and one has like a metal drum at the beginning of the side that goes to the tranny? Same thing?
Old Feb 25, 2023 | 01:19 PM
Old Feb 25, 2023 | 03:16 PM
bbond105's Avatar
The 6 speed manual and 4L60e driveshafts for a 98 LS1 Camaro are the same length, as best I can remember. The automatic had an aluminum driveshaft and the 6 speed manual, T56 trans had a steel driveshaft.
Old Feb 25, 2023 | 05:37 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
All of the manual LS1 cars came with an aluminum shaft, no steel shaft for them in the 1998-'02 years.
On the other hand, an auto trans could have either aluminum (3.23 gear, GU5) or steel (2.73 gear, GU2) shaft.
Old Apr 30, 2023 | 08:56 PM
P31Jeff's Avatar
the drive shaft length is 40.5" on a LS1 98 T/A with a 4L60 center of the U joint to center of the U joint l
