Moser 12 bolt question
Old Apr 4, 2023 | 04:04 PM
leftysrepsol's Avatar
Default Moser 12 bolt question
So I ended up shearing off the top 2 bolts of the torque arm mount on the rear end and bent the crap out of the mount. The bolts were tight and all the way in, I checked the length of the top bolts to the bottom bolts after I extracted them. Has anyone drilled and tapped the pumpkin to 5/8 bolts to so they match the mount holes? The holes were ovaled out a bit so I'd like to avoid putting 1/2 bolts back in it. The front holes look to be clear to use a long factory style bolt, I'm checking the rear holes to see, there is alot of material in the way and I'd rather not take off too much material due to the pumpkin being cast and loosing strength. Anyone have any other options?
