swapped rear ends
Old Apr 22, 2023 | 05:40 PM
rdpeach's Avatar
Default swapped rear ends
Hi there, new member. I have a 2000 ta, previous owner said the owner before him changed out the rear end. Abs and traction lights on. I want them off.
Took the guts off the axle and it had the abs speed sensors at the ends of the axle.
But NO tone rings infront of them (guessing the reason the lights are on)
People have complained about the difficulty of installing the rings and said i was better off getting a used rear end.
Which i did. 2000 camaro. Now this DOESNT have the speed sensors at the ends of the axle.
Now i feel like an idiot. Esp asking permission from the wife to buy it lol
Should i just try and get some tone rings for the current one....or put the used one on and go from there?
Old Apr 22, 2023 | 06:46 PM
jetech's Avatar
Veteran: Air Force
It is not hard to install the rings... it is just a fair amount of work.
Old Apr 22, 2023 | 06:49 PM
rdpeach's Avatar
Where can i get some? Ive seen 1 site selling them for almost $200 a piece
Old Apr 23, 2023 | 07:25 AM
Gene Cheeseman's Avatar
Are you searching for the right part?
https://www.wholesalegmpartsonline.c.../24202711.html
https://dieselpowerusa.com/alloy-usa...-camaro-11321/
https://www.hawksmotorsports.com/98-...bs-ring-hawks/
They're easy to install, just heat them up with a torch and they drop right on.
Old Apr 23, 2023 | 07:32 AM
rdpeach's Avatar
Thanks so much for those links! Before I make a purchase I noticed some say automatic and some say five speed. I have a 6 spd I'm guessing the ones from Hawkes are probably the proper ones to buy
Old Apr 23, 2023 | 07:38 AM
Might want to give them a call. I've been looking at this and some, like the top link, are for the transmission. Even though it says wheel speed sensor tone ring.
