Recommendations for aluminum driveshafts?
Old Dec 14, 2025 | 03:13 PM
LS1Formulation's Avatar
Default Recommendations for aluminum driveshafts?
After replacing a couple of parts in my driveline, my driveshaft was on the ragged edge of being too short. I had about 3/8" of travel in and out of my trans with the slip yoke. The combination of a Quicktime bellhousing and a Strange pinion yoke shortened up my center to center distance by close to 1/2". So I sold my steel driveshaft and figured now was a good time to upgrade to aluminum. It's been a long time since I've bought a driveshaft, and I figured I would ask what companies are good to source from. I was looking at Denny's Driveshaft and PST so far, which are comparable in price. If anyone has recommendations, I'd appreciate it.
Old Dec 21, 2025 | 09:28 PM
91 Z28's Avatar
I bought a PST chromoly 3" shaft and I'm very happy with it. I know I'll never have to worry about it. Everything was exactly how I ordered it. If you're looking at making big power I wouldn't even glance at aluminum chromoly is superior
Old Dec 22, 2025 | 05:30 AM
Doug G's Avatar
Only issue I've found with aluminum driveshafts are the size being a lot bigger than steel shafts and causing clearance issues.
Denny's would be the go-to IMO...IF you're set on aluminum.
Old Dec 22, 2025 | 08:13 AM
01CamaroSSTx's Avatar
I have purchased two now, one for each of my cars.
01 SS has a Strange steel 3"
99 Camaro has a PST aluminum 4"
Weight difference oh yeah the aluminum is lighter
Best DS would be carbon fiber.
Old Dec 22, 2025 | 09:15 AM
wannafbody's Avatar
Weight difference should be about 5.5#.
Old Dec 22, 2025 | 10:24 AM
I ended up buying an aluminum PST shaft used from @5.7stroker on here. I'm likely never going over 1000 RWHP with this car, so it will work fine for my needs.
