Pulsing Squeaking From Rear....
Old Jul 31, 2004 | 01:56 AM
Ferocity02's Avatar
Default Pulsing Squeaking From Rear....
I thought I had this problem fixed, but I guess it came back. Anyways, I drove through a pot-hole maybe 8 months ago and right after the rear driver side wheel area started squeaking. I replaced the bearing, axle, and rotors and its still there. The squeaking is pulsing with every wheel rotation. I kinda think it might be the e-brake shoe rubbing the inside of the rotor, but I'm not sure how to center or align it. Anyone have any ideas? Thanks!
Old Aug 1, 2004 | 10:49 PM
Ferocity02's Avatar
TTT, would still like some help with this
Old Aug 4, 2004 | 12:16 AM
Ferocity02's Avatar
No one?
Old Aug 4, 2004 | 03:05 AM
distortion_69's Avatar
I had this prob and the backing plate was a little bent, and it was rubbing.. Nothing a hammer couldn't fix
Good Luck,
Josh
Old Aug 4, 2004 | 11:56 AM
Ferocity02's Avatar
What was the backing plate rubbing on?
Old Aug 5, 2004 | 07:52 AM
Nine Ball's Avatar
LS1Tech Co-Founder
my girlfriend's Trans Am does the exact same thing after she ran over a curb. I've replaced the calipers, wheel, rotor, pads and it still does it. I'm guessing the axle is bent and was planning on replacing that next. If it is a backing plate, that would be nice, but I'm not sure how that would get bent by a pothole or curb?
Old Aug 5, 2004 | 01:34 PM
Mine was rubbing on the rotor.
Josh
Old Aug 5, 2004 | 07:00 PM
skippytheloon's Avatar
Mine makes that sound on left hand turns, haven't hit any potholes though.
Old Aug 5, 2004 | 08:15 PM
Could be the caliper. My old lt1 used to squeak because of the caliper dragging when taking sharp turns.
Josh
Old Aug 5, 2004 | 10:19 PM
Ferocity02's Avatar
I removed the caliper and used lugs to hold the rotor on tight. When I turned it, there is a rubbing sound on every rotation. I think its rubbing the inside of the rotor, but can figure out how to fix it. I moved the e-brake shoe around, but it still rubs.
