9 inch assembly & install
Old Aug 19, 2004 | 03:50 AM
badass 2002 z28's Avatar
Default 9 inch assembly & install
I'm getting ready to assemble & install a 9 inch in my car within the next week. Any special tips on doing this? The 3rd member is already together...just gotta get the backing plates off my 10-bolt, and press the bearings on the axles...
Do I install the 3rd member and then slide the axles in? Also how much fluid do these hold? and is it OK to use synthetic fuild like royal purple?
Thanks
Old Aug 20, 2004 | 12:12 AM
anyone? I know there's a few of u out there that've done this...
Old Aug 20, 2004 | 02:34 AM
hawaiiboysz's Avatar
I heard that you gotta use regular gear oil. and you gotta throw the 3rd member in first or else the axles will be in the way.
Old Aug 20, 2004 | 06:20 AM
BTL FED's Avatar
third member goes in first, then the axles go in, then add oil, very easy. I use redline oil in mine
Old Aug 20, 2004 | 06:27 AM
Hardtop's Avatar
Moser says DO NOT synthetic oil.
Bruce
Old Aug 20, 2004 | 11:20 AM
Flamin Raven's Avatar
I think people that do run synthetics do cuz of personal preferences. I just don't want to run cheap gear lube in an expensive rear end.
Old Aug 20, 2004 | 11:24 AM
yeah I wasn't sure on the whole syn VS reg gear oil debate. Anyone else got any input on this?
Old Aug 21, 2004 | 02:14 AM
35th SS's Avatar
do not use syn. oil. 80/90 will do.thats what I use.
Old Aug 21, 2004 | 09:25 AM
Fireball's Avatar
just like was said...install the 3rd member then slide the axles in. Make sure to tighten the backing plate bolts adequately...maybe use a lockwasher since they can back out on you if you're not careful
My moser 9" takes ~1 gal of gear oil to be filled
Old Aug 21, 2004 | 11:30 AM
LT1Burnout's Avatar
i recommend 90wieght in the posi
Old Aug 21, 2004 | 03:01 PM
I have a full spool, guess I'll just use regular oil. Thanks for the replies
