Few 12 bolt questions
Of course, if you go with a more aggressive gear in the 12 bolts (3.73's and higher) over the stock 3.42's, you will net better accelerations despite the loss of rwhp.
Yes, hard launches with an M6 + sticky tires will usually kill the 10 bolts. There is no real "weak part" as the entire rear end is "weak". The 10 bolts was designed for the Vega back in the late 70's, not for a 300+ rwhp car.
Thanks, Ryan
Thanks, Ryan
What kills a ten bolts at the track: wheel hops, dumping the clutch at high-rpm (shock), having an aftermarket clutch and sticky tires.
The A4 are less prone to break their 10 bolts because they can preload them, unlike the M6's.
