8.8 dumb question
Old Aug 24, 2004 | 12:57 PM
bsmith98's Avatar
Default 8.8 dumb question
Why do you have to weld the 10 bolt axle tubes onto the 8.8 housing? Is the 8.8 not wide enough?
Old Aug 24, 2004 | 01:04 PM
Zippinzee's Avatar
I am not sure but I believe it is because of all the brackets on the original axle tubes that mount springs and shocks and the ends so you will be able to use your original brake set up.
Old Aug 24, 2004 | 01:23 PM
m1key99WS6's Avatar
Correct.
bsmith98's Avatar
is there any ways of getting around this, i can get a 8.8 for $150 in good condition. Looking for cost effective ways. I know people that can weld very good, so if they could just fabricate brackets and put them on there it would be nice.
Old Aug 24, 2004 | 04:03 PM
OWENMUSTANG's Avatar
this is a major project. use the search. atleast one board member has attempted
their own version of this swap. the only part of the 8.8 you use is the center housing
and caps. everything else from something else. axle tubes stock 10 bolt. carrier from
eaton/auburn/strange/ect, axle shafts moser, gears fms. if you have the skills and
the parts guessing you might save 600/700 but, how many have you done?
do you have the cash to experiment? cheaper to go with something somebody else
has worked the bugs out of (and has a warranty) than the "i can do it cheaper" line.
after all, it's only a rear axle, how important can that be?
