Converting A 9"....
Old Aug 26, 2004 | 10:42 PM
LS1CMR's Avatar
Default Converting A 9"....
i have a 9" rearend housing from a ford, what modifications and where will i get them to make alll the suspension mounts and as i will have to buy a thirdmember, does anyone make them with a torque arm mount, thanks chris m.
Old Aug 27, 2004 | 08:36 AM
Fireball's Avatar
You are better off getting a moser 9" housing that has all the suspension mount points and torque arm mount complete.
You will run into problems with the torque arm mount, backing plate mounts, and possibly overall width of the housing. Geometry is crucial.
Old Aug 27, 2004 | 06:46 PM
LS1CMR's Avatar
#1, the thirdmember of a 9" is up front and the torque arm mount is already on it, plus i could get one from moser, already solved that problem, will bolt right in.
#2 all i need to know is how to make the suspension mounts or will i need to get a doner 10 bolt and cut them off of it and weld them on the new axel tubes
Old Aug 29, 2004 | 08:10 PM
Full-Force's Avatar
yeah, cut the brackets off your 10 bolt and weld them to the 9"
i know a dude that got a 9" from a old ford and made it work on a 3rd gen car
Old Aug 29, 2004 | 09:10 PM
LS1CMR's Avatar
cool, thats all i needed to know, not to mention im on a budget
