for 3.73 gear drivers
Old Sep 14, 2004 | 11:50 AM
sfwalters's Avatar
Default for 3.73 gear drivers
I have read a million(feels like it) past threads about shift points but can't find any good written numbers for where to set them with 3.73 gears. What have you guys set your rpm's/ mph's/ and rev limiters at with 3.73? Thanks. I am having trouble at dyno in 2-3 hitting rev limiter and finding right shift points.
Old Sep 14, 2004 | 03:47 PM
sfwalters's Avatar
Input Anyone? Am I The Only One With This Set-up? Or Just No One Else Cares To Answer?
Old Sep 14, 2004 | 04:08 PM
xxtinktFormula's Avatar
From: In the Keebler elves freg'n tree house eating freg'n cookies
You should PM "Ragtop99" or "Colonel". They are the kings of this stuff.
Old Oct 4, 2004 | 10:27 PM
mako22's Avatar
TTT - have the same set-up, having the same issue, can't find the info either!!!
Old Oct 4, 2004 | 10:36 PM
Zach@Texas-Speed's Avatar
i tagged the rev on 2-3 shift at the track this weekend when sprayin...im goin to tsp asap
Old Oct 5, 2004 | 08:08 PM
Ragtop 99's Avatar
You gotta play with your shift points. Mine are way higher than stock because of my cam. FWIW, I found that the part throttle shift points needed a lot of work to get it to feel good and my WOT downshift points needed a big adjustment.
If you are tagging on the spray you may need to back them down a bit (is your tranny up to the task ). I also found that shift points that worked great on the street did NOT work at the track with my ET Streets. At the track, I need to back them down 2 mph on he 1-2, and 4 mph on the 2-3.
Lastly, After I switched to 3.73s, my 2-3 was prone to hitting the rev limiter if I raced in D, but if I raced with the selector in OD, everything worked fine.
