Changed d/s, now vibration
shafts are at the vibration frequency he's talking about
here. And as to why the "better" steel shaft would make
vibration worse, I can't surmise on the materials basis?
Still think it has to do with the mass the U-joints have
to push around, pinion angle and maybe the absolute
joint angles in this case.
Here's my thread for reference:
https://ls1tech.com/forums/gears-axles/225429-vibration-over-65mph-twisted-driveshaft.html
What you're describing sounds kind of like what you get with a stiff suspension, and the vibration just kind of goes with the territory. How long have you been driving around with your current suspension/bushings?
