Problem When Installing A 4.10 Gear
I noticed that the ring gear was wider than the 3.42 ring gear. This caused the pinion block not to go in straight and was binding against the ring gear. Should I grind on the pinion block shaft to get clearence or tap on the pinion block and take a risk on damaging the teeth on the ring gear.
