Why do the LS1 12 Bolts break when the......
Now I know that a lot of guys have made them work but why have some not been able to g make them live?
Later,
Bart
The people making these housings now arent as accurate with their manufacturing as GM was when they made them originally. I think that is why you see more noise problems with them also. They arent made in very large numbers, so there isnt as much R&D going into them either. The 9" 3rd member on the other hand is made in very large numbers, and the housing itself just needs to be rigid and has nothing to do with the geometry of the gear set. When you set up a gear a couple of thousandths can make a difference in gear life and noise, and I dont think the housings are made with close enough tolerances.
Take a 70' chevelle for instance, with about 450 ft/lb of torque and massive wheel hop problems that every car had, STOCK 30 sline axles(everybody today runs a bigger axle), and they weighed about 4000 lb!! Wheel hop puts more strain on a rear then side stepping the clutch. As far as the posi unit itself going, If your talking clutch pack, that has been a common problem since the begining of time. I have to rebuild my clutch pack about once every year or two. That is just normal maintance if you want a tight posi. I like how I can ajust my preload also. That is my .02
