Third gen rear end question
Old Dec 4, 2004 | 10:46 AM
exodus's Avatar
Default Third gen rear end question
Compared to the fourth gen stock rear, how does the stocker in the third gen hold up? Are they the same? Will they handle a little more abuse? I am putting an LS1/T56 combo into an 88 formula, and the formula still has the stocker in it, and I was wondering if I would have issues like I did in my 98 camaro. The ls1 is only pushing around 330HP at the wheels. What do you guys think?
Chris
Old Dec 4, 2004 | 06:54 PM
mzoomora's Avatar
14 Second Truck Club
Except for the 9 bolt rears they are basically the same. The earlier 3rd gen cars have 26 spline axles, which are weaker compared to the 89-up 28 spline axles.
Old Dec 4, 2004 | 07:59 PM
badjuju342's Avatar
Deranged Rat Fink
As long as you don't use drag radials or slicks, it has a decent chance at survival.
Old Dec 12, 2004 | 08:22 AM
exodus's Avatar
would i be able to use the moser 9" that I have for my 98 camaro and still be able to use the 3rd gen wheels?
Old Dec 17, 2004 | 01:49 AM
burnrubber's Avatar
based only on the assumptions that 3rd / 4th gen rears are swappable, and that 4th gen rears are a few inches wider than 3rd gens, you should, however your wheels will stick out 1.5-2" further on either side. Whether they will rub depends on how big the tires are, how low the car is, etc. Some other things to consider are driveshaft length, brakes & their connections..
Good luck. I wish my ls1 3rd gen was finished. I still need to build the garage first
Old Dec 18, 2004 | 02:45 PM
exodus's Avatar
lol, thanks.
