4.10=slow??
Old Dec 11, 2004 | 02:35 PM
BIG RED's Avatar
Default 4.10=slow??
alright i have 4.10s and i swear my car wants to kick my *** if i try to push her past 113 MPH whats the deal shouldnt it at least be able to pull 125-130 MPH
Old Dec 11, 2004 | 02:52 PM
Mooobunnny's Avatar
Ummmm.......automatic or 6 speed? Need more information. Is this on the street....at the track....etc?
Old Dec 11, 2004 | 02:56 PM
mike c.'s Avatar
My car still tops at 120-123mph in 4th gear on 275/40/17's and 160mph in 5th gear,my car is a m6. i have my rev set at 6,800 and in 5th i never hit the rev so i could top at 165mph or so. is your rev set at stock 6,100rpm's? it sounds like it is, you should only top at 115mph in 4th and 150ish in 5th. if you want more,then move the rev up to 6,500-6600rpm's.if your car is an auto you will not top as high with 4.10's,like a m6 will.
Old Dec 11, 2004 | 03:40 PM
Mooobunnny's Avatar
Well.........third gear max speed in the A4 with be about the same as 4th gear max speed in the M6. Could be some variance because of the converter though.
Old Dec 11, 2004 | 04:28 PM
Tranzor's Avatar
With the stock rev limiter you have to put it in 5th gear for speeds over 113... 113 = rev limiter with the stock rpms set.
Old Dec 11, 2004 | 11:17 PM
BIG RED's Avatar
sorry guys.......its an A4
just running it on the street but i cant get any top end......whats my problem
Old Dec 12, 2004 | 03:01 AM
BoonesZ's Avatar
hmm should be something else when I had 4.10s in my A4 I could get up around 140ish
