Breakin in gears question.
Old Dec 18, 2004 | 04:52 PM
Breeze's Avatar
11 Second Truck Club
Default Breakin in gears question.
How long do you wait till you run youre vehicle hard after a gear swap? When should I change the gear oil?
Old Dec 19, 2004 | 09:31 AM
HavATampa's Avatar
This info was taken from Randy's Ring & Pinion website:
Even with synthetic oils, I still recommend the following procedure for breaking in a new gear set: After driving the first 15 to 20 miles, stop and let the differential cool before proceeding. Keep the vehicle at speeds below 60 mph for the first 100 miles. I also recommend putting at least 500 miles on the new gear set before heavy use or towing. During the first 45 miles of towing, it helps to go about 15 miles at a time before stopping to let the differential cool for 15 minutes before continuing. This is necessary because not all of the gear tooth is making contact until it is heavily loaded. When towing, the teeth flex to contact completely, and cause the previously unloaded portion of the teeth to touch and work harden. It is very easy to damage the ring & pinion by overloading before the teeth are broken-in. If you take it easy on a new ring & pinion and keep it full of high quality oil, it will last a lot longer.
With regards to limited slip additives, I have found that using too much additive can lead to premature gear wear. Use just enough to keep the limited slip from chattering but not more than 4 oz for every 2 qts of oil. It is a good idea to change the gear oil after the first 500 miles in order to remove any metal particles or phosphorus coating that has come from the new gear set. This is cheap insurance and a good time to discover any problems before they grow too big.
Old Dec 19, 2004 | 04:45 PM
GT Griller's Avatar
I ran that weekend at the track right after i had them put in. Raced my friend from a stop light the day i picked it up. He took me to get the car and we a caught a red light so we raced. I would prolly do what it says up top just for safety but i can tell u that my didn't mess up cause i didn't break them in maybe im just luky.
Old Dec 21, 2004 | 04:05 PM
Breeze's Avatar
Thanks for the info.
