Putting in gears
Old Dec 19, 2004 | 02:22 AM
ruck98's Avatar
Default Putting in gears
I Am Thinking About Putting 3.73 In My Car How Hard Is It To Do It Yourself And What Will I Need
Old Dec 19, 2004 | 07:50 AM
WJ SOM SS's Avatar
It is a tricky job, if you have never worked on this type of thing before. There are many little tricks that competent installers know about bearing pre-load, gear contact pattern, pinion nut torque, and more. If the job is botched in any way, many expensive parts can be quickly ruined. If you consider yourself a good mechanic, and have a good instructional manual, you can give it a shot...but proper setup and break-in is a must if you want positive results.... WJ
