One Wheel Burnout while turning??
I'm glad I found this thread. I have an 02 Z with 10k miles on it and have the same problem i.e right wheel spins only when turning right. One of my friend owns a Firehawk and I told him my situation and he told me its cause of my differential and that its normal. My other friend has an 98 Z and he does not have the problem. So being that I still have warranty I dropped it off today at the dealer. Stay tuned for what they diagnosed.
"Camaros and Firebirds equipped with the Zexel Torsen axle can have a clicking noise related to "radial gear float". WHen the differential is not laoded, the side gear can achieve a neutral bias and float in the planetary gear set. When load is applied either in coast or pull, teh side gear fully contacts the planetary gear set eliminating the float. When gear float occurs, a slight clicking noise can be heard. This is a normal condition and no repairs should be attempted to correct the complaint.
This is where it gets interesting.
Clicking noises when the gear set is loaded can be an indication of components other than the differential set. Things that may cause a clicking noise: look at the face of the ring and pinion and side gears for nicks or look at the bearing faces for sings of scratches or pitting."
I tried it on mine and when I just roll it clicks. when i apply "load" or give gas, it goes away. I have regain somewhat peace of mind. As I posted before both my friends also have the Auburn rear end, the 98 Z and the 02 Hawk. FerariGuy3, you might want to get that checked out asap, yours should most defenitly not make noises.
http://www.supermotors.org/getfile/1...ture%20031.jpg
http://www.supermotors.org/getfile/1...ture%20033.jpg
http://www.supermotors.org/getfile/1...ture%20034.jpg
http://www.supermotors.org/getfile/1...ture%20035.jpg
http://www.supermotors.org/getfile/1...ture%20036.jpg
http://www.supermotors.org/getfile/1...ture%20038.jpg Best Side View
http://www.supermotors.org/getfile/1...ture%20039.jpg Best Upper View
The shop I talked to told me that my clutches were worn out too, but there's nothing inside that looks like a clutch pack to me at all. In all honesty, the only thing inside is gears. That doesn't mean the unit isn't dead, it just means that I still don't know what is messed up inside mine. Sucks. New diff for me I guess.
