shudder
Old Jan 23, 2005 | 06:51 PM
ncarlson's Avatar
Default shudder
when i am turning right ,i have shudder comming from rearend.< only happens on hard take offs> doesn t make a sound when going forward or turning left. took rear cover off ck d and changed gear oil + additive.gears are fine also near as i can tell all bearings are ok to. could it be just bad shocks and or springs?
94 camaro z28 a4 140,000 runs like new
Old Jan 27, 2005 | 01:27 PM
elderon's Avatar
Not too likely. Its probably still something related to your rear end. Changing the fluid was a good idea - but if that didn't fix it - it could be something related to your limited slip. With the miles on your car I wouldnt be surprised if that was the problem.
Old Jan 27, 2005 | 06:38 PM
Richiec77's Avatar
Yep. That symptom is the posi not desingaging properly on one side or the other. Is is a Clutch Stlye (ie. Eaton)? If so that is definetly the clutches. If it is an Eaton you can re-build them.
Old Jan 27, 2005 | 09:30 PM
ROCNDAV's Avatar
What about the Zexel Torsen?
Old Jan 28, 2005 | 06:48 PM
ncarlson's Avatar
has what came stock that year . i think it is a eaton
