what are gears
If you have an Automatic LS1 camaro with stock 3.23 gears, you could run a 8.7 in the 1/8th mile. However if you put a 4.10 gear in the car, you will have a much better 0-60 time (much better) and your gears will shift faster, causing your top speed (normally around 160) to be around 145)...
I put 3.73s in my A4 99 Z28. I would not go higher than a 3.73 for a daily driver automatic car, but for a 6 speed you will be fine.. Also, do some research on rear end breakages, the higher you go in gear ratio, the easier it is to break. If you are just daily driving in an Automatic (A4) you probably wont have a problem, but if you drag race frequently you may want to invest in a whole new rear end.
I went from a 3.23 to a 3.73 and dropped 3 tenths off of my 1/8th mile time. There was a huge difference in pickup from a stop especially, and I have never tried to max the car out yet.
Good luck!!!
