Help in deciding on a 9inch.
Old Feb 8, 2005 | 12:28 AM
BOWTIE's Avatar
I guess you are one of the lucky ones... There is no way my T/A would fit un-modified, the T/A mount on the Moser housing is crooked. Have you checked your drivetrain angles to see where they are at?
Originally Posted by pontiac
mine fit fine with no grining or shims.
Old Feb 8, 2005 | 12:29 AM
pontiac's Avatar
yep they are good
Old Feb 8, 2005 | 06:18 AM
BOWTIE's Avatar
Do you mind me asking what they are? I have an adjustable T/A and still can not get mine right. I have the pinion to driveshaft angle correct with the pinion being about 1 deg farther down than the driveshaft; however, The tranny output shaft is about 1 deg farther down than the pinion. I think I will have to shim the crossmember a little to bring the tail shaft down and increase the angle of the tranny. I have a poly tranny mount and I suspect that it may be thicker than the original and raised the back of tranny a little also.
yep they are good
Old Feb 8, 2005 | 09:39 AM
Tally TransAm's Avatar
dont get a auburn.
i blew mine out after 1500 miles and now i need to find a locker for it
Old Feb 8, 2005 | 10:01 AM
bigdsz's Avatar
Bowtie, I didn't do my install, a drive line shop did. It took a day and a half, I know they had to grind some on the TA mount. I told them whatever they did I didn't want them changing the pinion angle, and they agreed. Everything works well other than a whine in the center section.
I had a lengthy discussion with Moser about the install before I bought, they repeatedly told me that as long as I kept the OEM TA, sway bar, pan hard rod and trailing arms it would be a bolt in installation. That, as I found out was not totally true. On the other hand, it wasn't an install from hell either. Best of luck.
Old Feb 8, 2005 | 08:07 PM
badpewter-z's Avatar
LS1TECH Sponsor
i have about 10,000 on my moser with 35 spline axles, detroit locker, stock tq arm bolte din with no issues at all really just had to cut the e-brake cable brackets . i find it very streetable as long as you can understand its gonna click taking turns in parking lots and may snap here and ther on a crooked take off(like backing out of a driveway whell cut all the way and then leave oppisite way). now the rear isnt even a worry on race day
Old Feb 9, 2005 | 08:10 AM
M6HTZ's Avatar
I am considering doing the install at home with the help of a friend on jack stands. I know its going to be ugly, but I plan to get the Billinglesly kit complete with backing plates and fully assembled. According to them it is a direct bolt in. I guess I'll find out.
Old Feb 9, 2005 | 04:31 PM
waltsfastz's Avatar
Is drive shaft lenght an issue on 9 inches?
Old Feb 9, 2005 | 04:33 PM
LS1TECH Sponsor
nope just put a 1350 ujoint in the back and your good
Old Feb 9, 2005 | 09:54 PM
bigdsz's Avatar
I just had a 9" installed, the stock driveshaft fits but it is only 44 inches long. I just got a Denny's Nitrous which is 45 inches long. The measurement is taken from the back of the transmission tail section to the front of the center section yoke.
