Another leaking rearend question
Old Feb 9, 2005 | 03:21 PM
stock98z's Avatar
Default Another leaking rearend question
Hello, I recently purchased a 98 z28 w/a4. I have maybe put 10 miles on the car since I have had it. It has been sitting in storage now for about 35 days and I noticed a puddle under the rear end. Just upon first glance it looks as if the leak is coming from the front side of the housing, where the DS connects. I guess this would be a pinion seal of some sort. The puddle is about 10 in. in diameter. I dont plan on driving this car until may, how hard of a fix is this? I am planning on uprgading the gear to a 3.83 or taller. What are my options for a semi descent rearend without having to drop $2000 on a moser or the likes. (Im a newb to F-body) Thanks!
Old Feb 9, 2005 | 04:27 PM
00Streak's Avatar
Here in Texas I know a guy, that would be able to install new gears(correctly),replace all the seals, and fill ya with fluid for aroung 4-500 out the door. Not sure where you are located but im sure geographic locations wont effect price THAT much. Hell, I see used stock 10-bolts selling for 150-250(some with and some without backing plates). Worse case, If its to pricey to fix the one you have, buy a low mileage one and replace the whole thing.
Old Feb 9, 2005 | 06:07 PM
stock98z's Avatar
Thanks, thats not a bad deal. I am located in Houston.
Old Feb 9, 2005 | 06:28 PM
Uno99's Avatar
Just got all mine done today install was 250$ pinion seal is 10$
Old Feb 9, 2005 | 07:22 PM
00Streak's Avatar
my 4-500 was including gears. so that 250 is about right. gears avg 200.
