Panhard Rod Adj or non?
Old Nov 13, 2001 | 01:50 PM
SSuforia's Avatar
Default Panhard Rod Adj or non?
I'm going to lower my SS but I'm keeping the same tire and wheel size. 275/40 17's. I plan not to change the height or wheel size. Do I really need an adjustable panhard rod or just a regular rod?
Old Nov 13, 2001 | 01:53 PM
Rob98Z's Avatar
Default Re: Panhard Rod Adj or non?
You'll need a adj. PHB to set your rear back to center after you lower it. Even if you don't need to adjust it after lowering, it's still good to have. <img src="images/icons/wink.gif" border="0">
Old Nov 13, 2001 | 02:03 PM
ChrisB's Avatar
Yep, you only need it if you lower/raiser your car, or if you change the rear end.
A new bar with poly bushings should help with cornerning though. You will probably only notice this if you push your car - e.g. auto-x, etc.
Chris
Old Nov 13, 2001 | 02:08 PM
Judd's Avatar
I agree with Rob98Z, it don't cost that much more. The ajustable part comes in handy.
