Picture of new 9"
Old Feb 11, 2005 | 03:38 PM
bigdsz's Avatar
Default Picture of new 9"
Here's a picture of my newly installed 9" Moser housing and Strange center section.
Old Feb 11, 2005 | 04:42 PM
bigdsz's Avatar
Let's try again, the resolution is getting worse and worse.
Old Feb 11, 2005 | 06:27 PM
waltsfastz's Avatar
Looks good. How much did the housing set you back?
Old Feb 11, 2005 | 06:54 PM
2MuchRiceMakesMeSick's Avatar
Reddd....
I painted mine flat black. Its different.
Old Feb 11, 2005 | 07:27 PM
Fireball's Avatar
thats one red rear
Old Feb 11, 2005 | 08:02 PM
bigdsz's Avatar
The housing was $970 with 31 spline axles and drain and fill bungs, plus $175 for reluctor rings. I also got 3" 1/2"x20 screw in axle studs. The red idea came from PSJ's 9".
Old Feb 11, 2005 | 08:12 PM
98 camaro's Avatar
that looks real good....i like the red
Old Feb 15, 2005 | 01:36 AM
w02ramair's Avatar
Default the rest of it
How much did the whole install cost ya? Thats not a bad price for the housing and axles. Just curious what the third memeber cost ya.
Old Feb 15, 2005 | 01:54 AM
TheBlurLS1's Avatar
That's what she said...
i was hoping to see a picture of a red rear end! i primered/painted my moser black. used a high temp gloss black engine paint for the top coat. it was nice untill we wrestled it into place
looks nice though, just a bit to HEY LOOK AT ME for me
Old Feb 15, 2005 | 02:30 AM
35th SS's Avatar
looks good except the swaybar looks small for the 9in.what brand is that or stock.have the spohn on mine.
Old Feb 15, 2005 | 05:19 PM
bigdsz's Avatar
It should look small it's the stock sway bar. At some point I'll go bigger but all in all I'm very happy with the way the 9" install went. I wouldn't call it a direct bolt in by any means, however I finally have peace of mind that my rear isn't going to blow when I dump the clutch at 4-5,000 rpm.
Old Feb 15, 2005 | 09:37 PM
QuickSilver's Avatar
where did you get the rear for that price? im in the process of buying one now.
Thanks
Josh
Old Feb 15, 2005 | 09:52 PM
bigdsz's Avatar
Give Jay Billingsley a call, he is very knowledgeable. He will remind you of things like fill and drain bungs, solid crush sleeve, the correct size studs for your application etc,etc,etc.
Old Feb 17, 2005 | 02:40 PM
LoPeY's Avatar
That looks really good, I've never seen a red rear end before.
Old Feb 17, 2005 | 08:53 PM
Elite_Hot_Rod's Avatar
Here's a couple of pics of my new Billingsley 9".
Old Feb 17, 2005 | 11:08 PM
cyphur's Avatar
Elite, now thats a strong *** rear-end. What kind of setup, and how much did that set you back?
Old Feb 17, 2005 | 11:49 PM
Turo's Avatar
elite,
that thing looks badass! that's the kind of piece i wish i could afford.
Old Feb 18, 2005 | 09:24 AM
That's a Billingsley 9" with X brace, Strange 40 spline light weight gun drilled steele axles and 5/8 studs, Strange light weight steele spool with 3:50 gears, a Wolfe sway bar and the Strange light weight racing brakes, it was right at 4K.
Old Feb 18, 2005 | 09:54 AM
EZMONEY's Avatar
Reminds me of a FAB 9, looks very very nice. Thats not a bad price at all for that setup..........
